March 5th, 2011, 08:42 AM
#1
welfare wheeler
March 8th, 2011, 10:38 PM
#2
GLFWDA Member
This weekend wasn't so productive. Yesterday I spent about 6 hours driving to go pick up my doors, vent, and some other misc. items. I got home to find some family had came to visit unexpectedly so that pretty much took up the rest of my evening.
Today, the plan was to cut up a couple sheets of plywood into strips for the roof spars, cut the doors, glue up the roof spars, install roof spars and put on the end pieces of the roof. It didn't quite happen. It started with my table saw not cooperating, so I had to run to Home Depot and rent one. Got it home and cut up all the strips. After returning it, I came back home to glue up all my roof spars. Installed the ones at the back to close up the bottom part of my galley and started installing some at the front. Then I started on the drivers side door. It ended up taking me about 90 minutes to cut the hole. I just wasn't with it or something because no matter how many times I measured, it was still not big enough. Finally after cutting it waaaaay too many times, I got the door in. Then I put up a sheet of the roof on the front. It didn't cooperate either. After another hour or so to get one piece on, I gave up for the day.
I only took one pic after I got the door in. I didn't take any more as I was just too frustrated.
I need to finish what I set out to do in the next day or so. I'm putting on the front and back pieces of the roof so I can climb under it and do another coat of epoxy and seal up all the joints and edges. I'm thinking this will make the final epoxy much easier as I wont have to worry about any of the parts on the bottom. Hopefully I can get back in the groove again...
Oz
KD8NFX
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
