Results 1 to 9 of 9
Thread: Dana 44 front axle wanted for wide track CJ
    Default Dana 44 front axle wanted for wide track CJ
    Looking for a dana 44 front axle for a wide track CJ.
    I'VE GOTTA HAVE MORE COWBELL, BABY!!!
    '86 cj7
    You should just make it 2 wheel drive...
    Oz
    KD8NFX
    It's actually not broke. Yet. I try to BUILD (read: not buy) a strong enough rig to take what little I give it! lol
    You're right though. If only 2wd, you, Dan and I would all be on the same playing field!
    Actually I'm considering going to chromoly's in front, but thought before I spent that $ I'd see what was out there for a swap in D44.
    '86 cj7
    lol. Good response. You win. lol
    Oz
    KD8NFX
    Lower 41.5 GLFWDA Member Renegade II's Avatar
    Frankenmuth / Saginaw, Mi.
    1,144
    Quote Originally Posted by rentalrider View Post
    Then you'll just be chunking out R&P's instead of axles......and be just as pissed off....with less money in your pocket. Been there, done that.
    44's are easy to narrow & Moser cuts and resplines axles pretty cheap.
    welfare wheeler GLFWDA Member joe_jeep's Avatar
    Hazel Park, MI
    1,624
    talk to jeepaholic on gl4x4, im pretty sure he has one for sale that is already cut to cj widetrack width. someone on there did, im pretty sure it was him.
    i didnt catch a price though.
    good luck
    Got a couple 44's out of a Early Bronco driver drop $300
    Also a FW 44 out or a early J10 3.73's & a 44 rear to match $100 for the set.
    5 -5.5
    pm sent.
    '86 cj7
    Junior Member
    Feb 2010
    Brighton/Flint, MI
    I've got a full width dana 44 from a 1979 Jeep J 10. Passenger side drop.
  1. WIDE TRACK D30, AMC20 w/ ARB's 4:58
    By cjd-cj7 in forum For Sale - Parts and More
    Last Post: October 10th, 2006, 12:33 PM
  2. Front CJ Dana 30 Axle Housing
    By One Arm Steve in forum Wanted
    Last Post: February 21st, 2006, 02:35 PM
  3. Wanted dana 30 wide track shafts for a CJ
    By ovr-ez in forum Wanted
    Last Post: January 2nd, 2006, 09:39 AM
  4. Ford High Pinion Dana 60 Front & Dana 60 Rear
    By akozman in forum For Sale - Parts and More
    Last Post: November 9th, 2004, 09:18 AM
