Results 1 to 5 of 5
Thread: 97-05 Dana 30 axle shafts
    Senior Member
    Dec 2005
    East China, Michigan
    364
    Default 97-05 Dana 30 axle shafts
    Blew up the pass axle shaft on my 97 XJ today. I guess the combination of a stock 4.0 and 235/75/r15 tires is just too much for a dana 30. I took out both the inner and outer shaft. I need the entire assembly, and might be interested in both sides if someone has them.
    Shafts MUST be from a 97-01 XJ or a 97-05 TJ and MUST be of the 297 U-joint style, not the CV joint ones.
    For the right price I'll take an entire front axle if you have one.
    Best to call me, but you can also PM me.
    Keith
    810-614-8038
    Recovered jeep addict on the straight and narrow with Toyotas
    Vertically Challenged 4x4 GLFWDA Member phittie1100's Avatar
    Burton, MI
    2,455
    14
    That's clearly too much tire and hp for that axle....?? LOL
    Did the u-joint just let go?
    I've got TJ L&R inners and a single outer, free to a good home. The catch is they have rusty crusty u-joints that I don't have the time to mess with any time soon. I'm just south of I69, couple miles east of FLint.
    Senior Member
    Dec 2005
    364
    PM Sent!
    Senior Member
    Dec 2005
    364
    Quote Originally Posted by phittie1100 View Post
    Nope, and I just replaced both front U-joints when I installed my lockright less than 4,000 miles ago. The u-joint literally turned to shrapnel, taking both shafts with it. I was in four wheel drive, in the snow in my backyard, pulling a non-running four wheeler out when it gave out. I wasn't even being that rough on it.
    I am assuming that I got a bad u-joint from autozone with some sort of defect in it. They gave me a new joint, but they won't cover the shaft damage.
    Default Dana 30 Front axle
    If you havn't found an axle yet I have a complete Dana 30, 4-10 ratio new gears, bearings and Rock-It skid plate from a 04 TJ. No outer steering knuckles. Trying to get $1000 or might trade for a TJ Dana 44 rear axle.
    Elmer Phudd
  1. Alloy or Stock Axle Shafts D44 Next Day?
    By lgottler in forum Shop Talk
    Last Post: March 2nd, 2007, 12:16 PM
  2. dana 30 outer shafts
    By timmy_69 in forum Wanted
    Last Post: March 2nd, 2006, 01:48 PM
  3. Wanted dana 30 wide track shafts for a CJ
    By ovr-ez in forum Wanted
    Last Post: January 2nd, 2006, 09:39 AM
  4. dana axle survivel?
    By ganz in forum Shop Talk
    Last Post: December 22nd, 2005, 09:43 PM
