Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 39
Thread: PeatSorb
    Default PeatSorb
    As discussed at the October Quarterly:
    Contact kb8ymf (Jim M.) if you're interested in purchasing PeatSorb.
    I was wondering what this really is. is it just that peat stuff you use in gardens or is it made for oil dry use?
    I think its a specific type of peat that is dried a specific way.....?
    Quote Originally Posted by wrifrocks2005 View Post
    Peat moss that you get in stores has a high % content of moisture. With the moisture in it, it will not absorb the hydrocarbon base oils. It won't pick up the oil. The Peat Sorb is specially dried.
    jim-kb8ymf
    Interesting stuff, never heard of it before now.
    GLFWDA Member GLFWDA Member Trail_Fanatic's Avatar
    Muskegon and Oceana Counties
    2,170
    4
    Thanks for getting this up, Kevin!
    Pat Brower
    Quis custodiet ipsos custodes?
    we use the stuff at work. it soaks up everything but water. something about how its dried prevents water from being re absorbed. plus its really light to carry as compaired to clay based absorbants. last I knew were buying the stuff in roll and bag form
    Quote Originally Posted by Yetti View Post
    GLFWDA is purchasing it in compressed 4 Cu ft bales and dividing it out into containers of about 1.5 gallon size jugs. Working with Jarhead on acquiring a viable jug size to package it in. Right now the jug available from PeatSorb sells for $20. With doing the packaging work ourselves we hope to get it down to $15 or lower depending on what we can get arranged for the jug costs.
    We currently have a variety of sizes from 3 quart ziplock bags @ $5.00 to 5 gallon pales @ $35 and numerous sizes in between.
    jim-kb8ymf
    How do we go about buying some of this if we are interested?
    Question: Once it's used, it has to be picked up, if I'm understanding it correctly. Then where can it be taken for disposal?
    Great idea for off road runs. I'm going to suggest it to our club out west here to have on hand. Bashed oil pans are not uncommon out here.
    [CENTER]USMC INFANTRY
    Get your junk out on the rocks.[/CENTER]
