Results 1 to 2 of 2
Thread: Private Messaging
    Default Private Messaging
    The latest update of vBulletin (our forum software) has broken the product we use to encode private messages before storing them in the database.
    What does this mean? Basically, it means that the private messages will still be encoded in the database, but for some reason when you reply to a PM, the encoded version of the message will be quoted, rendering the quote unreadable.
    I'm working on fixing it, but am having a hard time tracking down exactly which part of the code is causing the issue.
    Until then, the best workaround is to copy and paste the quote (copy from the message before you reply to it).
    My coder did a patch for this. if you can email me your coding plugin to clarkstoncracker@gmail.com I'll have him modify it for you.
  1. private message info
    By WhiteRhino in forum Website Questions, Comments, and Suggestions
    Last Post: July 1st, 2008, 01:14 PM
  2. Replies: 3
    Last Post: October 23rd, 2007, 11:11 PM
  3. Liability on Private Free to use Land
    By lgottler in forum Land Use
    Last Post: March 1st, 2006, 06:11 PM
