Results 1 to 7 of 7
Thread: Brochure
    Default Brochure
    Could we link to the new brochure instead of the old one in the GLFWDA Documents section?
    High Res
    http://www.glfwda.org/boondocker/Tri...20HI%20RES.pdf
    Low Res:
    http://www.glfwda.org/boondocker/Tri...%203-12-08.pdf
    Lucas
    Quote Originally Posted by lgottler View Post
    High Res
    Low Res:
    Lucas
    If you can tell me where the link is to the brochure, I'll gladly change it
    1,760
    Try the GLFWDA HOME tab
    Then ABOUT US tab
    Look at lower right, under the pictures!
    I think that may be where he is refering .. at least it takes you to the old brochure!
    Thanks to Lucas and Kevin to keep these things current and working!
    THANKS GUYS!!!
    In the sub forums "GLFWDA Documents" there is a link to the Brochure, but its the old one....
    1,760
    OK, it is updated in the Forums, as requested by Lucas.
    It still needs updated on the Home page access, as I noted above.
    Thanks!
    Quote Originally Posted by DDS4X4 View Post
    Thanks!
    Working on it!
    1,760
    You the Man, Kevin!
    Fixed, THANKS!
  1. GLFWDA Brochure
    By Administrator in forum GLFWDA Documents
    Last Post: February 4th, 2008, 11:53 AM
