Results 1 to 10 of 15
Thread: St. Helen Motorsport Area
    West Side Trail Junkie GLFWDA Member Rubiclone's Avatar
    Mar 2008
    Spring Lake, Michigan
    6
    Default St. Helen Motorsport Area
    Wondering if anyone can give me some info on the off road area. I have never been there and am wondering if its worth getting the Jeep out there for a weekend sometime soon. I have heard and read that it is a great place for quads and bikes but I cant find much on 4x4 trails, rocks, mud, etc.
    Seeing as though I was directly involved in the St. Helen Motorsport area improvement advisory board I will do my best to answer your questions.
    First this is the size of the park itself, at 2 square miles it is the largest scramble area in the state. And being a scramble area you are allowed to travel cross country, as long as no live trees are harmed in the process.
    If you travel to the southwest corner you will find a sand bowl with several small hill climbs some of which will challenge a dual locked vehicle when the sand is loose. There are several other smaller sandy bowls as well as two tracks and open areas that were recently logged. These logged areas can be fun to use your right to travel cross country and wind your way through the deadfall and to some little hills.
    Future plans do include a rock course as there are none there now. It probably isnt a days worth of wheeleing but it beats sitting in front of the TV on a saturday.
    There are other two tracks and routes in the area so the rest of your day will not go unfulfilled. Just make sure a 2 wheel drive car can traverse these other trails (uless marked as a route) to keep it legal.
    Hope this helps!
    Isn't the sand bowl on the east side??????
    Quote Originally Posted by WhiteRhino View Post
    It seems that way when your there, but the Motorsport area itself runs east and west for the 2 mile stretch and north and south for the width.
    When you look at a map it makes sense, but when your there you swear it is the other way around. The sand bowl is on an east west road and is down at the west end of the park. So it makes it in the southwest corner.
    Disregard this post, I was the one swearing it was the other way around.
    1,765
    To add to Pat K original suggestions, it should go without saying ... but I'll add it anyways ... don't go wheeling alone. SO post up your plans here and usually you will get some others, ready willing and able to participate and probably available to show you around the area!!
    Quote Originally Posted by Ironman View Post
    Oh, kind sir, I beg to differ. I just checked my gps tracks and it's in the SE corner for sure. But, I don't have pdf configured on this computer right now so, I will have to do it from my other computer.
    Big drama here this morning.
    If Pat says it's in the Southwest corner, that's where it's at!
    And how would you know anyhow...you don't even have a running Jeep!
    j-kb8ymf
    Quote Originally Posted by kb8ymf View Post
    j-kb8ymf
    yea darnit
    The parking lot should be the southest corner, but no matter where it's at you should go there and climb some hills. But like Doug said, dont go alone!
    But after checking my map again Whiterhino is on to something, I refuse to say what it is though
    yea darnit
    In my best Schultz voice. 'I know nothing..."
    Oak Park, Mi.
    154
    Mr. Kitson is correct.
    The bowl area is in fact, in the Southeastern corner
    of the motor sports area. The road that travels adjacent is Meridian Rd. which runs north/south. It is also the coutny line between Roscommon and Ogemaw coutnies. Carter Lake rd. is just south of the bowl. The intersection of these 2 roads makes up the Southeast corner of the Motorsports area.
    Meridian Rd. makes up the Eastern boundry.
    E. Carter Lake Rd. makes up the Southern boundry.
    Ingleson Rd. is the Western boundry. This road turns east half way through the motorsports area, but the 2-track that heads south from the turn is still the boundry. Although it is not a straight line so the actual boundry make get a little fuzzy in that area. I do believe it is fairly well marked though.
    The Northern boundry is just north of the parking lot and fairly well marked.
    Some of what I just posted was to suppoer Mr. Kitson. Some was for information for the OP. And some was just because I like to type and jsut can't get enough. I also can not make short posts about anything.
    Oh, and Mr. Kinney, the parking lot is the extreme Northeast corner of the park
    And another thing. The park runs North/South for 2 miles and approx 1 mile East/West.
    You can easily see this when you look at the DNR map
    http://www.dnr.state.mi.us/spatialda...rv/sthelen.pdf
    and then reference Mapquest using the aerial view of the area
    http://www.mapquest.com/maps/Saint+H...:::::f:EN:M:/e
  1. St. Helen Area forest clean up.
    By brewmenn in forum Trail Cleanup
    Last Post: April 26th, 2010, 10:49 PM
  2. Cleaning up St. Helen Motor Sports Area
    By Jarhead in forum Trail Cleanup
    Last Post: May 4th, 2009, 08:07 PM
  3. How far is the motorsport area from the quality inn?
    By MuddyPaws in forum Events, News and Announcements
    Last Post: January 2nd, 2006, 03:10 AM
  4. St. Helen motorsports area rules
    By brewmenn in forum Land Use
    Last Post: September 20th, 2004, 10:01 PM
