Results 1 to 7 of 7
Thread: Michigan Vehicle Codes.
    Default Michigan Vehicle Codes.
    I see a lot of people running into issues with officers for tires sticking outside of the body, not enough mirrors, etc. Heres the laws.. I keep the abbreviated code in my YJ at all times. Even though I have 38.5" tires, they stick out the sides, and I don't have a passenger mirror, I'm still legal. Whenever I'm stopped, I nicely show the officer that commercial vehicle laws do not apply my multi-purpose passenger vehicle.
    Lifted vehicle document, including bumper height and frame height limits.
    http://www.michigan.gov/documents/hi...law_8580_7.pdf
    Abbreviated code **KEEP THIS IN YOUR GLOVEBOX**:
    http://www.michigan.gov/documents/ve...nts_8583_7.pdf
    Detailed code:
    http://www.legislature.mi.gov/(S(hsv...878&highlight=
    welfare wheeler GLFWDA Member joe_jeep's Avatar
    Join Date
    Jan 2006
    Location
    Hazel Park, MI
    Posts
    1,624
    4 inch lift and 35's on my tj is still legal with room to spare. i guess i need 37's now.
    Great information
  4. #4
    GLFWDA Member GLFWDA Member T-way's Avatar
    Join Date
    May 2004
    Location
    Just Below the Bridge
    Posts
    1,119
    I run 35x14.50 Pit Bull Rockers on my TJ with factory fender flares. The tires stick out about 4 inches from the outside edge of the flare. I've never had an officer make any issue of it. BUT.....I will print this information and keep it in the Jeep......just in case!
    Thanks for posting this!!
    President - Troll Four Wheelers
    Vice President - ATVOffroad.net
    I'm Still Out There - I Haven't Gone Away!!
  5. #5
    I didn't see anything about the tires extending outboard from the fender flares. Can you point me to a section for that, if there is one?
    K1QD--
    '77 CJ7, 360 AMC w/ DUI, headers, Edelbrock intake, Holley 4150, TF999, D300, D30 & AMC20, 4.56 gears, lockers, winch, fiberglass body. York Air Comp, 6" total lift, 35" BFG MTs, Garvin bumpers/racks.
  6. #6
    Lower 41.5 GLFWDA Member Renegade II's Avatar
    Join Date
    May 2006
    Location
    Frankenmuth / Saginaw, Mi.
    Posts
    1,145
    Quote Originally Posted by cc View Post
    That Technical Service Bulletin (read: For cops that can't even change their own oil cheat sheet) is handy, but has been outdated since (at least) 2005 when 257.714, a, b etc. were repealed. And it really failed to cover any of the intricacies of the law from day one. You’re way better knowing the whole law 257.710c (that it refers you to in lower box #5) if you’re going to own/build a lifted vehicle.
    Bad link
    Quote Originally Posted by OldSailor View Post
    It fell under the mudflap part at the bottom of the TSB (257.714a) and has since been repealed. It's CMV law, not applicable (unless your ride falls in here somewhere: 257.7.) Here's the newer section that replaced 257.714: 480.25
  7. #7
    Yeah, I've been down this road with the MSP. There is no requirement for mud flaps or fender flares for non commercial vehicles. That's why roadsters are legal too.
    KDSRGON GL#2665 KD8EGK
    Thanks to those that do all the hard work.
Similar Threads
  1. vehicle requirements
    By 93trackaddict in forum General Chatter
    Last Post: April 28th, 2008, 08:55 PM
  2. Pro-Hobbyist Street Rod and Custom Vehicle Bill Introduced in Michigan
    By Jeeperz-Creeperz in forum Events, News and Announcements
    Last Post: December 3rd, 2007, 03:56 PM
  3. Vehicle Lemon Law for Michigan
    By Yetti in forum Trail & Road Use Laws
    Last Post: July 22nd, 2007, 12:44 PM
  4. washing your vehicle at GG
    By WhiteRhino in forum Events, News and Announcements
    Last Post: September 19th, 2006, 09:06 PM
