Results 1 to 10 of 16
Thread: private message info
    Default private message info
    Why does the block in the upper right corner suddenly say I have 10 unread pm's when they have all been read?
    Quote Originally Posted by WhiteRhino View Post
    It had something to do with an update and some of the PM's have been marked as unread.
    If you go into your PM Inbox, click the box at the top right to select all the PM's, then at the bottom of the page select Mark as Read, it will fix that. (you may have to go through several pages to mark them all this way).
    Okey dokey....... thanks
    Member MrsRedRuby's Avatar
    Jul 2007
    Brighton, Michigan, United States
    95
    Default confused
    I received an email saying I had a private message and after clicking on the link it said I had 0 messages. Not sure what this is all about. Guess I am more computer illiterate then I thought....... Thanks for any help you can direct my way.
    1,765
    Probably "stephanie spam" ... see related thread.
    Not your computer skills ... but I know where you are coming from.
    Default Spam in my Private Inbox?
    Getting spammed by a user named Patricia
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    Quote Originally Posted by prooffroad View Post
    Got that one as well.
    Junior Member
    Apr 2008
    jacksonville, fl
    yeah i got one from "her" too
    Patricia this time? What is going on with site security?
    86 Bronco II : Blown 2.9-D35 /8.8 locked-4.56:1-5speed-BW1350M-33's-4" of lift-awaiting a heart transplant!
    Patricia and buddhism. Sweet!!!
  1. New Local Message Board
    By MuddyPaws in forum General Chatter
    Last Post: November 10th, 2005, 11:34 AM
  2. Message question
    By WhiteRhino in forum Website Questions, Comments, and Suggestions
    Last Post: November 2nd, 2004, 05:10 PM
