777.48 Operator ability affected by alcohol or drugs; “any bodily alcoholic content” defined.
Sec. 48.
(1) Offense variable 18 is operator ability affected by alcohol or drugs. Score offense variable 18 by determining which of the following apply and by assigning the number of points attributable to the one that has the highest number of points:
(a) The offender operated a vehicle, vessel, ORV, snowmobile, aircraft, or locomotive when his or her bodily alcohol content was 0.20 grams or more per 100 milliliters of blood, per 210 liters of breath, or per 67 milliliters of urine 20 points
(b) The offender operated a vehicle, vessel, ORV, snowmobile, aircraft, or locomotive when his or her bodily alcohol content was 0.15 grams or more but less than 0.20 grams per 100 milliliters of blood, per 210 liters of breath, or per 67 milliliters of urine 15 points
(c) The offender operated a vehicle, vessel, ORV, snowmobile, aircraft, or locomotive while the offender was under the influence of alcoholic or intoxicating liquor, a controlled substance, or a combination of alcoholic or intoxicating liquor and a controlled substance; or while the offender's body contained any amount of a controlled substance listed in schedule 1 under section 7212 of the public health code, 1978 PA 368, MCL 333.7212, or a rule promulgated under that section, or a controlled substance described in section 7214(a)(iv) of the public health code, 1978 PA 368, MCL 333.7214; or while the offender had an alcohol content of 0.08 grams or more but less than 0.15 grams per 100 milliliters of blood, per 210 liters of breath, or per 67 milliliters of urine or, beginning October 1, 2013, the offender had an alcohol content of 0.10 grams or more but less than 0.15 grams per 100 milliliters of blood, per 210 liters of breath, or per 67 milliliters of urine 10 points
(d) The offender operated a vehicle, vessel, ORV, snowmobile, aircraft, or locomotive while he or she was visibly impaired by the use of alcoholic or intoxicating liquor or a controlled substance or a combination of alcoholic or intoxicating liquor and a controlled substance, or was less than 21 years of age and had any bodily alcohol content 5 points
(e) The offender's ability to operate a vehicle, vessel, ORV, snowmobile, aircraft, or locomotive was not affected by an alcoholic or intoxicating liquor or a controlled substance or a combination of alcoholic or intoxicating liquor and a controlled substance 0 points
(2) As used in this section, “any bodily alcohol content” means either of the following:
(a) An alcohol content of 0.02 grams or more but less than 0.08 grams per 100 milliliters of blood, per 210 liters of breath, or per 67 milliliters of urine or, beginning October 1, 2013, 0.02 grams or more but less than 0.10 grams per 100 milliliters of blood, per 210 liters of breath, or per 67 milliliters of urine.
(b) Any presence of alcohol within an individual's body resulting from the consumption of alcoholic or intoxicating liquor other than the consumption of alcoholic or intoxicating liquor as part of a generally recognized religious service or ceremony.
http://www.legislature.mi.gov/(S(s25...&highlight=orv
777.55 Prior misdemeanor convictions or prior misdemeanor juvenile adjudications.
Sec. 55.
(1) Prior record variable 5 is prior misdemeanor convictions or prior misdemeanor juvenile adjudications. Score prior record variable 5 by determining which of the following apply and by assigning the number of points attributable to the one that has the highest number of points:
(a) The offender has 7 or more prior misdemeanor convictions or prior misdemeanor juvenile adjudications 20 points
(b) The offender has 5 or 6 prior misdemeanor convictions or prior misdemeanor juvenile adjudications 15 points
(c) The offender has 3 or 4 prior misdemeanor convictions or prior misdemeanor juvenile adjudications 10 points
(d) The offender has 2 prior misdemeanor convictions or prior misdemeanor juvenile adjudications 5 points
(e) The offender has 1 prior misdemeanor conviction or prior misdemeanor juvenile adjudication 2 points
(f) The offender has no prior misdemeanor convictions or prior misdemeanor juvenile adjudications 0 points
(2) All of the following apply to scoring record variable 5:
(a) Except as provided in subdivision (b), count a prior misdemeanor conviction or prior misdemeanor juvenile adjudication only if it is an offense against a person or property, a controlled substance offense, or a weapon offense. Do not count a prior conviction used to enhance the sentencing offense to a felony.
(b) Count all prior misdemeanor convictions and prior misdemeanor juvenile adjudications for operating or attempting to operate a vehicle, vessel, ORV, snowmobile, aircraft, or locomotive while under the influence of or impaired by alcohol, a controlled substance, or a combination of alcohol and a controlled substance. Do not count a prior conviction used to enhance the sentencing offense to a felony.
(3) As used in this section:
(a) “Prior misdemeanor conviction” means a conviction for a misdemeanor under a law of this state, a political subdivision of this state, another state, a political subdivision of another state, or the United States if the conviction was entered before the sentencing offense was committed.
(b) “Prior misdemeanor juvenile adjudication” means a juvenile adjudication for conduct that if committed by an adult would be a misdemeanor under a law of this state, a political subdivision of this state, another state, a political subdivision of another state, or the United States if the order of disposition was entered before the sentencing offense was committed.
