Results 1 to 1 of 1
Thread: New Users
    Default New Users
    If you are seeing this message it is because of one of the following reasons:
    If you have not registered with the GLFWDA Forums:
    You need to register in order to make any posts. It's quick, easy and painless. Once you register, you will be sent a verification email. If you do not get it within a few minutes, check your spam filter. Follow the instructions and you will complete your verification. You MUST use a valid email address.
    If you DID register with the GLFWDA Forums but cannot make any posts or log in:
    The most common cause of this is because you did not verify your account. Please check your email and your spam filter. There should be an email with instructions on verifying your account. Follow those instructions and you should be good to go.
    If this did not help you, ensure that your browser is set to allow cookies from our website.
    If you still cannot log in, please send an email to webmaster@glfwda.org and mention your forums userid and we will see what the problem is.
  1. Active users
    By offroadracer99 in forum General Chatter
    Last Post: July 26th, 2005, 07:07 PM
  2. Number of Forum Users
    By kerryann in forum Website Questions, Comments, and Suggestions
    Last Post: October 3rd, 2004, 01:14 AM
