Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: CJ5 AND CJ7 OWNERS FREE TILT STEERING COLUMN
    Lower 41.5 GLFWDA Member Renegade II's Avatar
    Frankenmuth / Saginaw, Mi.
    1,145
    <div class='quotetop'>QUOTE(scottdidit &#064; Apr 19 2007, 08&#58;00 PM) [snapback]24304[/snapback]</div>
    Sorry Shawn, darn I thought this might be easy&#33;&#33;&#33; I&#39;m hitting every cj site i can find. Any suggestions?? where are the cj5 owners that need tilt columns??? This is a &#036;300.00 -&#036;400.00 column.
    The 72-75 CJ5&#39;s are low quality years with frames that crack easy and cheap bodies that rusted before they left the lot. Sadly most are scrapped out. Your best shot at an unmolested steel body 5 is here: http://www.earlycj5.com/forums/index.php
    Any finders fee reward? Kidding, good luck&#33;
    Edit: A post 71 CJ6 uses the same column as the 5.
    So,,,, can anyone verify the 71 jeepster has the same column as the CJ5???
    email sent&#33;
    PM sent
  5. #15
    Senior Member
    Dec 2005
    East China, Michigan
    364
    Why didn&#39;t I read this a few days ago? My ignition rod broke inside my column on my CJ8 Scrambler (same as a CJ7 from seats forward) A buddy of mine who owns a junkyard spent the entire day rebuilding the column.
    However, if you are looking to look past the Automatic trans requirement, my 1982 CJ8 Tub is steel and very unmolested.
    Recovered jeep addict on the straight and narrow with Toyotas
  6. #16
    Thank you All, for your help. We got what we needed. One person here also got a free column, Thanks Joe&#33;&#33;
    The new columns will be available soon.. mid July... I&#39;ll ad a note here to let anyone know the exact date.. thanks again.. Scott ididit inc.
  1. Ididit column
    By ovr-ez in forum Shop Talk
    Last Post: April 10th, 2007, 09:24 PM
