Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 32
Thread: clock
    Frank,
    The clock needs to be corrected.
    Senior Member yogi's Avatar
    Aug 2004
    laingsburg mi.
    467
    yeah i address this yesterday
    yogi
    1,765
    It still appears to be off by 4-5 hours.
    Edit: Make that +4, it's now 1:16 am.
    1,765
    still +4 hours or is it a setting on only MY computer?
    SquattingDog
    for some reason.. the clock works perfect for me. check your profile.
    -frank
    WILMA
    Thanks for the info Frank.
    My clock works right now.
    1,765
    OK, I checked my time on my profile and I adjusted my time on my controls. It only showed being off 1 hour. Hope this works now. Thanks for the response.
    EDIT - Yes, it is correct now!
    Inkster, Michigan
    436
    I'm still seeing it one hour off. I have mine set to GMT -5 hours and that daylight saving time is in effect.
    For me it says I posted this at 1:35 but it is actually 12:35
    Bruce
    Individual member #6774
    SquattingDog
    I love it... the Clock forum is the hottest forum of on the board !!! Bruce try turning Daylight saving off. and or select EST time rather than -5 GMT.
    -frank
    I have mine set to EST and it works like a charm.
