Results 1 to 3 of 3
Thread: Grant Opportunity for Clubs
    Default Grant Opportunity for Clubs
    From Extreme Terrain Off-Road Outfitters:
    Click image for larger version.
    ExtremeTerrain’s Clean Trail Initiative Program is ramping up and is looking to improve the trails near you. The Clean Trail Program was founded by ExtremeTerrain in 2015 and setup to fund trail improvement projects that can include anything from trail clean-up, trail restoration, trail expansion, and more. ExtremeTerrain has worked with numerous Wrangler and 4x4 clubs/groups as well as many privately and publicly owned off-road trails to enact changes for the betterment of trail conditions for the communities being served.
    To date, ExtremeTerrain has granted over 22 grants for trail improvement projects, funding just under $10,000 in trail improvement projects all around the country. In just the past few months for spring/summer 2017, ExtremeTerrain has approved an additional 10 grants and is shooting for more.
    Applying for a Clean Trail Grant is easy; head to https://www.extremeterrain.com/clean...veprogram.html and click to apply for a grant, filling out a short questionnaire. With a grant from ExtremeTerrain, you can get the tools you need to clean, restore, or expand your local trails, helping to maintain the trail system and improve it for future off-roaders.
    Passing along this opportunity for our clubs to get a few dollars toward some local trail work.
    GLFWDA
    This is a great opportunity to show your commitment. The Two Trackers Have been recipients of this a few times. While it isn't a huge amount it does help offset any cost associated with your project.
    ../|. ,[______],
    |---L =O|||||||O
    ()_) .()_)--~---)_)
    Thanks Lucas!
    '78 CJ7, AMC 360, T18, Dana 20 w/Tera Low gears, Locked Dana 44's F&R, AJ's Tub, Matkin frame.
