Results 1 to 5 of 5
Thread: GL4x4 login issues
    Senior Member
    Join Date
    Dec 2005
    Location
    East China, Michigan
    Posts
    363
    Default GL4x4 login issues
    Hey I know a bunch of you use GL4x4.com.
    Awhile back I got an email to change my password due to some security thing. I was busy at work and didn't get to it. Now I seem to be locked out. Any suggestions?
    Recovered jeep addict on the straight and narrow with Toyotas
    Senior Member GLFWDA Member Ms.ZJ's Avatar
    Join Date
    Dec 2008
    Location
    Muskegon, Michigan, United States
    Posts
    439
    Make your posts here instead, at least you can log in here.
    Quite the Conundrum
    Vertically Challenged 4x4 GLFWDA Member phittie1100's Avatar
    Join Date
    Jan 2006
    Location
    Burton, MI
    Posts
    2,449
    Blog Entries
    14
    You have to go through a convoluted password reset, and use a predefined 10-digit p/w, then replace it with your own 10-digit p/w. Or access through Tapatalk, for some reason that was easier to get reconnected
    Paul - 2005 Wrangler Unlimited
    KD8PAV
  4. #4
    The parent company got hacked so they did a wholesale reset on every one of their websites including Pirate. To me, I'm glad they made the effort to make it more secure. If it were me, I would create a new temporary user and then PM ClarkstonCracker. He has been handling these issues as they come up.
    KDSRGON GL#2665 KD8EGK
    Thanks to those that do all the hard work.
  5. #5
    Senior Member
    Join Date
    Dec 2005
    Location
    Posts
    363
    Thanks for the replies! I went through the convoluted process and got it all set. Working like crazy right now but hoping to be more active soon!
    Sent from my 0PM92 using Tapatalk
