September 7th, 2014, 10:43 PM
#1
JK electric locker not working
It does not engage when the power goes to it. It gets full voltage and draws about 3 1/2 amps which is normal. Have any of you had one of these stick? I just wonder if it has some debris in it that keeps the engagement ring from sliding? If the coil were bad, I couldn't see it drawing the correct current.
September 8th, 2014, 05:51 AM
#2
Sounds logical. Have you popped the cover? Water in the dif causing corrosion?
September 8th, 2014, 09:36 AM
#3
Not yet. I think thats a good next step.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
