Results 1 to 3 of 3
Thread: Driving Lights On
Hybrid View
Previous Post Previous Post   Next Post Next Post
    Default Driving Lights On
    I have a 2004 TJ Sport. It has the fog/driving lights on it. Is there an easy way to wire them so they stay on when you put the bright headlights on?
    Dave
    Best way I have done in the past is to hook the driving lamp relay signal to the bright light circuit, add a switch in between if it's necessary to turn them off.
    There was a YouTube video on this that I saw the other day they took the relay out the is near the fuse box behind the glove box. They said I the one on the right then they just bent over one of the tabs and reinstalled it and magic they stay on when the brights are on. Hope this helps
