As I usually am, I was present at the 3-6-13 ORVAW meeting in Lansing. Back in 2009,I believe Polaris solicited Rep Joel Sheltrown and successfully amended the definition of an ATV.
OLD version of MCL 324.81101 [A ] * 3-4 WHEELED VEHICLE, DESIGNATED FOR OFF-ROAD USE, THAT HAS LOW PRESSURE,BALLOON TYPE TIRES, WITH A SEAT THAT IS DESIGNED TO BE STRADDLED BY THE OPERATOR, POWERED BY AN ENGINE FROM 50cc ON UP TO 500cc.
AMENDED VERSION OF MCL 324.81101 [ A ] on 12-29-09 *3-4 or 6 WHEELED VEHICLE DESIGNED FOR OFF ROAD USE, THAT HAS LOW PRESSURE, BALLOON TYPE TIRES, WITH A SEAT THAT IS DESIGNED TO BE STRADDLED BY THE OPERATOR, POWERED BY AN ENGINE FROM 50cc ON UP TO 1000cc
I contacted Sheltrowns office regarding this amendment back in 2009 when they were drafting it. I believe his Rational for the amendment was so that the Polaris Side x Sides could be included as an ATV, which didn't change it to an ATV anyways, because you don't STRADDLE the seat on a Side X Side [ even with the amendment, the SxS is still an ORV ]. The rational was absolutely meaningless because the Polaris SxS was already established as a ORV under Michigan law and since it was wider than 50 inches, it didn't matter if it was classified as an ATV or an ORV, it could STILL only be used on a ORV Route because of its WIDTH. They rushed the amendment on 12-29-09 so they wouldn't have to re-claim it in 2010. His amendment did absolutely NOTHING for the Polaris SxS here in Michigan IMO.
NOW, we have SB 0068 at our hands introduced on 1-24-13 which : VEHICLES, OFF ROAD, DEFINITION OF ATV, REVISE TO CREATE SEPARATE CATEGORY OF RECREATIONAL OFF-ROAD VEHICLES. AMENDS SECS 81101,81129 & 81130
We already have ENOUGH confusement over what the difference between an ATV and an ORV is. Now with 0068, we will have yet ANOTHER catagory of ORV, the ROV
''ROV'' MEANS A VEHICLE WITH 4 OR MORE WHEELS THAT IS DESIGNED FOR OFF ROAD USE, HAS NON HIGHWAY TIRES, IS MORE THAN 50 INCHES IN WIDTH BUT NOT MORE THAN 65 INCHES IN WIDTH, AND IS POWERED BY A 50cc - 1000cc GASOLINE ENGINE , AN ENGINE OF COMPARABLE SIZE USING OTHER FUELS, OR AN ELECTRIC MOTOR OF COMPARABLE POWER
BEFORE Sheltrowns amendment on 12-29-09, the above ROV was legally classified as a ORV under Michigan law and could only be operated on ORV Routes because it was wider than 50 inches in width. Than Sheltrown meaninglessly amended the definition of an ATV in 2009 [ IMO ]. Now we have Senator Hansen playing the same meaningless game [ with SB 0068 ] as Sheltrown did in 2009 by wanting to classify this ORV vehicle over to an ROV.
It does not matter if you call the Side x Side a PIG in Michigan. If ANY Off road vehicle is wider than 50 inches in width, it can still only be operated on ORV ROUTES or designated scramble areas-- [and parts of PA 240 ] PERIOD! REGARDLESS OF WHAT YOU CLASSIFY IT AS!
Most of Michigan's newer [ and many older ] ORV riders already have a hard enough time understanding where they can legally operate an ATV or ORV, now we have to confuse them even more by adding yet another meaningless [ IMO ] catagory of ROV to the mix.
WHY?
