Did this repeater ever get up and running?
I came across this while doing some research on DI for a trip i'm going on in a month.
If it's up and running, does the repeater have an autopatch?
Well, I looked a bit online and from what I see, yes it's active but no autopatch. 147.36 w/ pl 110.9
Anyone use it yet?
Jerry
Sent from an undisclosed location...
Yes! We used it up at Drummond Off-Road Adventure 2012.
Coverage was pretty good, I made contact with repeater out and the stair steps at marble head. There are "shadows" throughout the island where you just can't get good reception, I think shale beach is one of them, but if you drive up the trail a bit to get out of the low area you can hit it again. for what it is worth, I was using a Yaseu 2900r with a Metz 5/8 wave bottom load whip (Michigan proof 2 meter antenna and only 37 inches long!) so with was pushing 75 watts when out on the edged or in low signal area.
I apologize for not being as active on here this summer, went through some rough times with with a close family member. I hope to be more involved now.
Thanks for the info.
Wow I'm surprised you couldn't hit it at 75w.
Unfortunately FM is primarily line-of-sight. Repeater antenna height, mobile antenna height and terrain all play a factor.
Sent from my DROIDX using Tapatalk 2
