Results 1 to 9 of 9
Thread: amc 20 one-piece chromoly shaft (passenger)
    Default amc 20 one-piece chromoly shaft (passenger)
    Jeep is sitting at Standish Transmission. I need the passenger rear shaft. AMC 20, 1-piece and chromoly (just like I broke ). Anyone have any recommendations on where to pick one up at a decent price? Thanks in advance.
    I'VE GOTTA HAVE MORE COWBELL, BABY!!!
    '86 cj7
    Lower 41.5 GLFWDA Member Renegade II's Avatar
    Frankenmuth / Saginaw, Mi.
    1,144
    Sounds like it's time to upgrade from the 20.
    Make you a deal on a set of 60's
    He just needs to learn how to drive it. hehehehehe
    Oz
    KD8NFX
    Quote Originally Posted by Renegade II View Post
    I'm listening!!
    '86 cj7
    Quote Originally Posted by oz97tj View Post
    I'm not listening!!
    '86 cj7
    Moser
    1,144
    Quote Originally Posted by rentalrider View Post
    I'm listening!!
    You'd have to flip your T case drop over to the other side, they're currently under a 79 Ford F350 SRW
    Quote Originally Posted by WhiteRhino View Post
    Moser
    that's what i ended up doing. and that's what was in there before, too.
    '86 cj7
    Next shaft I break I'm hitting you up! Should have done this when I swapped transmissions. I pulled the tc off the t18 from a ford that i put in and had to get an adapter to the 300. Not buying that $$ adapter would have prly gotten me close in price to the axles! I still have the other tc though, so like i said, we may speak in future about this.
    '86 cj7
