Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 50 of 50
Thread: SnoFari 2011 SoFficial Thread
  1. #41
  2. #42
    Member MrsRedRuby's Avatar
    Join Date
    Jul 2007
    Location
    Brighton, Michigan, United States
    Posts
    95
    HELP!!!!!!! Here it is a week away and the stupid engine light is once again coming on. They said it is an electrical problem and it won't let the computer connect and read the error code. Their best bet is there is a wire broken or shorted out or whatever but said the only way to find it is test each wire so depending on how fast they find the problem it could take an hour or 10 hours at a measley $100 an hour!!!! Anyone have any cheaper suggestions? I am ready to cry and Steve is just plain mad. Should we say screw it and just come anyway and ignore it???????
  3. #43
  4. #44
    Lower 41.5 GLFWDA Member Renegade II's Avatar
    Join Date
    May 2006
    Location
    Frankenmuth / Saginaw, Mi.
    Posts
    1,144
    If it's running good, has oil pressure & is charging I'd drive it. Generally the light will flash on and off at you if it's anything real bad. If I had a penny for every mile I've put on a vehicle that had an illuminated 'check engine light' I could have retired somewhere around 1988.
  5. #45
    Join Date
    Jul 2007
    Location
    Posts
    95
    thanks guys......those are my feelings too. now to get Steve to see it my way. he is bummed because he can't drive and I get to do offroading for the first time. between him and the jeep I think they are conspiring to keep me from behind the wheel.
  6. #46
    Pic of mrsredruby from last year
  7. #47
    One more of MrsRedRuby
  8. #48
    Formerly Ultimate Air Business Member Brian81CJ's Avatar
    Join Date
    Apr 2004
    Location
    Allen Park, MI
    Posts
    208
    Well, if it makes you feel better, my Check Engine light is on now too... And it's probably still going to be on Saturday!!
  9. #49
    Bring it. The worst you can do it win the SoBroke award.
    KDSRGON GL#2665 KD8EGK
    Thanks to those that do all the hard work.
  10. #50
    Join Date
    May 2006
    Location
    Posts
    1,144
    For the attendees; Who plans to be there and ready to hit the trails Friday am?
