Results 1 to 5 of 5
Thread: Post Times
    1,765
    Are the post times set off some other time standard than Michigan time?
    Like if it's 2:00AM OR 10:00 AM, my clocks in Ohio are way off.
    I know it's a techy thing, but I was just curious? Besides, now I have 2 posts.
    Thanks, ---Doug
    Go to your personal settings and you can edit the time zone that you are in.
    Jeremy
    I may need to adjust the master time zone in the config, I'll have a look at that today.
    Buster
    just select GMT -5hrs and select the daylight savings box.
    hope I'm right!
    Jeremy
    Initially the time was off for everyone, but I have fixed that. You will still need to adjust your personal settings for server time, as the server is located in a different time zone.
  1. how many times can you say Ironman offroad in one post?
    By WhiteRhino in forum General Chatter
    Last Post: December 10th, 2008, 07:18 PM
  2. OSTC Event Article In The Bay City Times
    By Rattler in forum Events, News and Announcements
    Last Post: December 5th, 2007, 10:04 PM
  3. Gitchee Gumee arrival times
    By lgottler in forum Events, News and Announcements
    Last Post: September 24th, 2005, 12:01 AM
